Should I assume I'm at the start of exhaust port corrosion? I have a 04/04 225 Yamaha that I use in brackish water only ( the upper Hudson River . Prior to put ting my 25' Parker in the water I filled it w/ 170 gallons of fuel. The engine has 569 hrs. This past week-end I took the boat out and was not able to go faster than 17-19 kt's with the engine revving at 5100 rpm's. Although I'm carrying 1500lbs of fuel i don't think that should affect my speed that much. Is loss of power one of the first signs of exhaust port corrosion and if so what else should I look for?
Exhaust port corrosion
