I recently was going to pull my lower unit of my 115HP 2-stroke Yamaha to change my water pump impeller. After removing the 6 bolts, trim tab and the bolt under the trim tab section the unit still wouldn't drop. I removed the lower mount cover looking for a bolt when I learned it is spring loaded, now cant get the cover back on. What do I need to do to get the lower mount cover back on? Your help will be greatly appreciative.
lower mount cover
I can't think of anything on the lower unit that is spring loaded... can you clarify or post a picture or maybe even the parts diagram for your motor?
Lowers sometimes get stuck (salt buildup) at where the driveshaft enters the crank - often, but not always, the reason is not dropping it on a regular basis and/or not using proper grease on the splines. You might need to get creative with wedges, hammering, etc.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
I'd take a guess the front (with one bolt being at the rear) of #27, may have a tab that has to be inserted first perhaps?
Then push in the rear and THEN insert the bolt.
Why there's a spring there, ??
Got this pic from E-bay, pic of your part (used). I strongly suspect that curved section,
at the very top pf the pic, slips over the engine area(with the spring), then install your bolt.
.Last edited by TownsendsFJR1300; 02-24-2021, 03:08 PM.Scott
I think when I tried to get the cover on the other day I didn't have both springs aligned where they were getting compressed, but yesterday I got it back on first try. I want to thank you all of you for your guidance that gave me the confidence to get it on with out taking it to a shop or breaking anything.
Glad to hear you got it back on. Weird about the spring, though - I mean, obviously it's some type of vibration dampening, but my bracket/cover does not use a spring, even though they're pretty much the same design overall. Gotta wonder why the difference, you know?2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
