1997 yamaha 130 outboard saltwater series high rpm problem
  • 1997 yamaha 130 outboard saltwater series high rpm problem
    I have a problem with a 97 130 I had about 1200 dollars done to it to get it running(carbs rebuilt,neutral switch and a ignition switch).I got it back and tried to run it it would idle good and when moved to higher rpms it would shake badly,took it back and they put a oil float and comp box I think that's what it's called.still did the same thing.So they tried a good stator and all the electrical under that.I ran it and it will run for I would say about 5-10minutes then shake badly and I would lower the rpms for a second or more and raise the rpms and it would sometimes run for a little while or it would just shake badly.like it would detune it.any suggestions of what it could be thanks
