Here are the symptoms:
Turn the Key to the on position and the fuel pump stays quiet.
Turn the key to the start position and nothing happens.
There is 12 volts at the starter and at the starter relay.
There is 12 volts at the trim relay and trim works fine
This began as an intermittent problem that I initially chalked up to battery/connection issues. Now it won't make a peep.
What I have checked so far:
Battery
All connections from battery to engine
All fuses in the fuses block are good (checked with multi meter)
Neutral switch has continuity
Engine stop lanyard switch works properly
Starter relay changed and verified
The main and fuel pump relay checked as per the service manual.
I am not sure how to check the ignition switch or the harness for continuity.
Any ideas? Thanks
Battery
Any ideas? Thanks
