Cdi Unit for Yamaha F80 Bet 2008
  • Cdi Unit for Yamaha F80 Bet 2008
    Hello !
    I have a Yamaha F80 Bet 2008 4 stroke outboard.I need to buy Cdi Unit with nr.6D7-8591A-11 for this type,new or used.Please tell me where to find this cdi unit or anyone who is compatible.Thanks
    Click above on the RED : PURCHASE YAMAHA PARTS above and it should be there.
    The prices here are a bit better than at the dealer..
      Hello Scott
      thanks for reply but link isn't working.
        This is a Yamaha USA website.
        A 6D7 CDI is not available in the US. It has not been used on any motors that have been offered here in the US. Therefore, it will not be available via any of the US Yamaha outboard motor dealers.
          do you know any CDI who can be compatibile with 6D7 ? Maybe 6D8 or 6D9. thanks
            You may check with your local Yamaha dealer and see on the availability.
            Where are you located(curious)?
            I did find this CDI but its off one # (-10- vs -11) when you look thru the PDF;
            http://www.yamaha-nautica.com.br/Con...2013094303.pdf
            Page "D4"
              The -11 is a replacement for a -10.
              Problem is, the motor that uses his ECU was not offered here in the states and thus the ECU will not be available here. Some parts are the same as parts used on USA Yamaha's but some are not.
              I sure do like the way those parts books are laid out. Easy to search. Plus, they are savable in pdf format. Too bad Yamaha US does not offer theirs in this format. Which I suspect they do for a reason.
                So whatever country he's located in (I'm assuming outside the US with a NON-US engine) shouldn't that CDI be available there?
                  I would think so.
                  I also think prices are cheaper here. People want cheap.
                    I am from Albania.The CDI in Europe costs about 1300 Euro and its found only in 2 websites.I am trying to find all the opportunities to repair the engine and i heard that are some Usa models are compatible with F80.Thanks for your Replys.Regrades
                      What is the problem with your ECU? Why do you think that it needs to be replaced?
                      $1300/1300 Euro is a terrible price to have to pay. Taxes.
