I have a F70 that has recently developed a stalling problem when under way. Occurs when the boat is cruising at 20 mph or more. The problem does not occur at slower speeds.
The motor will shut off dead as if the safety switch was pulled and will immediately start again when ignition switch is turned. It runs smoothly without any shuttering or spark knocking. The fuel bulb is full and battery connections are good.
I had a mechanic run a diagnostic on the motor, but there are no coded saved.
I anyone has an idea what the issue may be or has had a similar problem, please let me know.
Thanks.
Thanks.
