starter cranks with remote shifter in any position
    Key on ungrounds the white wire. Key off grounds the white wire.
    To pull start the motor the key would have to be turned to the on position first. Then to stop the motor turn the key to the off position.
      keyswitch-schematic.pngThis is probably not the exact right diagram but it shows the connections for on--off--and start, with W connecting to B= gr. in the off position.
        Yes. White wire grounds the CDI so no spark occurs.
        • #19
          I sure do appreciate your patience - Thanks again Bill
