I have my jet pump torn apart to replace seals, decided to replace the bearing while its out. My service manual doesn't have any info on pressing it back together, or at least what I was looking for. Once all disassembled, we looked at the bearing pressed on the shaft, with the thrust collar on top, but it just seems that it was pressed together with built in free play between the thrust washer and bearing, and that is what I'm trying to find out. Is there a tolerance or measurement that this bearing is pressed on the shaft to the trust washer? My unit is the Yamaha Z model
Jet pump bearing
What service manual do you have?
It should be LIT-18619-00-03 or the equivalent.
http://outboardjets.com/miscellaneous-instructions/
