the only function of the regulator is to maintain rail pressure at a specified pressure.
the ECU does NOT monitor rail pressure it assumes its correct.
at rapid throttle opening the vacuum sense line has a lowered vacuum(higher pressure) and adds about 5PSI on the rail.
this allows for the sequential AND group injection nessasary to accelerate smoothly with no backfire in the intake.
remember manifold pressure is an inverse to manifold vacuum.
at or near WOT intake vacuum will be close to 0"Hg.
manifold pressure will be about barometric pressure.
what is the MAP sensor showing at key on engine off?
sometimes the motor can suffer altitude sickness.
I can tell you for a fact the 2007 F250 can operate at 22,000 ft.
when the map sensor failed the ECU read the input as 22,000 ft and adjusted the fuel curve accordingly.
it ran like crap at se*****l.
the EFI F60 runs very well when all is good and all the thingy's are happy.
you simply have to figure out which thingy aint happy and fix it.
ALL the engineering work has been done.
I usually start with a basic leakdown test to make sure the cylinders can actually seal.
then I move on to a simple spark test to see if the spark PRODUCING components can do the job.
then its on to test the fuel system.
you should see an EFI 5.7L Volvo run when the rail pressure is above 100 PSI.
spec is about 55 PSI.
