Hi all
Need help with the 1989 yamaha 50DETO. Seems that the prime start or automatic/choke is pretty much allways on roughly 15-20seconds and running high rpm regardles wether the engine is warm or cold.
When the prime start goes off the enging is idling at the normal rpm and you can put the gear on.
Prime start can be turned off using the lever but that does not solve the issue itself. Any ideas for this issue?
