I got up this morn and check the continuity from the ISC connector to the ECU connector. There was continuity for all 4 wires. So that's not the issue.
With the cover off I listened for the rattle sound of the ISC and couldn't hear. I had my ear and finger on the ISC and didn't feel or hear any rattling noise. I'm assuming that it's an obvious sound. I started/stopped several times and never heard the noise.
NOTE: one time when started the idling seemed to run normal but all other times it had the loafing idle.
Is there anything I can do to verify the ISC is the problem. From what RB17 says it sounds like it's stuck in the open position.
The part on boats.net is $210+shipping.
At this point the issue seems to point to the ISC. Is there anything that could be suggested that I could do to absolutely verify that this is the issue? Perhaps jumper the pins at the ISC connector to trick the ECU into normal idle operation. Can this be disassembled/cleaned, probably not?
I'm wide open for suggestions.
