All started after I put 130 carbs on to go a bit faster. Would bog out trying to plane (had to hit choke to get past bog)and 3 out of 4 times at full throttle. If it didn't bog at full throttle it was 3 mph faster than 115 carbs.
Figured had to be fuel. Cleaned carbs again, carefully set floats (only slightly low), new fuel pump,changed 10 micron filter in boat as well as one on motor. Doing same thing. Change out ALL the gas. no change. Changed fuel lines and cleaned carb again. Checked vent on tank. Changed primer bulb. New plugs. NO CHANGE! Pulled pickup on tank. Thought maybe too close to bottom. Took 1/4 in off. NO CHANGE
Tried the 115 carbs today....was sure it was something wrong with 130 carbs. SAME DEAL exactly. Unless I missed something it seems it can't be fuel related so checked timing and link and sync. NO CHANGE
All I can think now is CDI or a coil bad. Stator? Bad plug wire?
Please help me....I'm stumped....
