Hi all first post new to the forum. If I'm swapping the pump one for one should I have to adjust the linkage from the carb to the pump? Does anyone have detailed steps on pump removal and replacement and bleeding/priming the system? Thanks again Robert
keihin oil pump swap
I can't speak from experience, but if it's a simple swap without messing with the linkage to start with, wouldn't it go right back on without adjusting?
However, there are more experienced people on this forum that can give you a better answer. But you need to be patient. Not everything in life is available on YOUR schedule. Sometimes you have to wait.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
I don't think the Keihin pumps are available. They were replaced by Mikuni pumps in 1990.
Yamaha USA offers a pump "kit" that is used to convert from the old pump to the new pump.
And yes, it should be adjusted once it is installed. I am old enough to remember having to replace points. They had to be adjusted upon installation.
By the same set of gears for a lower unit and guess what? They have to be inspected and adjusted, if necessary.
I thought this went through about a half hour ago, but I guess not... I meant to add:
I would wait till someone more experienced responds before starting on the repair - just in case there's something I wasn't thinking of.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
