F40 2006 Carb Syncronize
  • F40 2006 Carb Syncronize
    Hello
    I have a Yamaha F40 model of 2006 and I want to syncronize the 3 carburetors, I have a vacuum syncronizer like this http://www.ebay.com/itm/181181293414...%3AMEBIDX%3AIT but whatever I do I can't syncronize them.
    Could anyone help me?
    Are you following the procedure in the service manual? It worked great for me, although I was using a vacuumate. Your use of gauges should not matter however.
      I don't have the service manual.. only owner's manual
        Hope this can help
          Thank you very much for your help!
          I follow the instructions but the manometer indicators are bouncing at 900rpm...they stay stable only when I reach 3.500rpm..
            See if you can borrow a vacuumate device. So much easier than trying to work with vacuum gauges.
              undampend vacuum gauges are about usless.
              I owned a set for a bit,loaned them out and lucky for me they never came back.
              you will either need a dampend set or a vacuum mate type.
                My vacuum gauge has an adjustable valve for each gauge..If I close the valves until the indicators stop bouncing will it shows me the right amount of vacuum?
                  Yes, thats what should happen
                  I have a similar vacuum gauge set and thats the way I tune carbs on my F100, on the my F40 I havenīt tuned the the carbs yet.
                  Donīt close to much the valves as you may have a wrong reading. Sometimes you may need to readjust the valves during the process.
                  Vacuummate its a nice tool but very expensive for a non professional of the business (IMO) at least for my pocket.
                  I've been chasing a used vacummmate for more than 2 years on ebay at good price but had no luck as is a tool worth good money even on 2nd hand (min 350/400 $ or €)
