2016 200FXCA with 500hrs, well-maintained. Intermittently she will struggle out of the hole at WOT, and max out about 5-600rpm less than 6100max. No rhyme or reason. Also happens while running, will suddenly drop rpm and infrequently will pop back up to max while running.
- Fuel is good, always from reputable E-free pump. Always E-free gas, never more than a month to burn a tank
- fuel filter element changed regularly, and this week most recently. No water in that filter housing.
- fuel/water separator changed regularly, and this week most recently. No water in fuel.
- VST filter at bottom of tank changed this week. Original/existing filter was nearly black, so figured that would be the cause - it wasn't
- AFTER the VST lower filter replacement didn't fix, yesterday replaced the VST F-filter at top of tank - will run it today but the existing filter wasn't discolored like the black filter in the bottom.
Anyone experienced same? My internet-fu has turned up most likely issue would be that VST-bottom fuel filter, and that wasn't it. Local shop replaced the fuel filter and F-filter in top of VST in January and that seemed to address for a few months until recurrence around March.
Thanks for your replies.
