T60TLR No Spark
  • T60TLR No Spark
    Engine is turning over but not starting up. Tested each spark plug with a spark tester. No Spark.
    Was going to check the continuity of the kill switch lanyard. What is the easiest way to test the kill switch?
    Disconnect the leads to the kill switch and then test for continuity. Switch should be open with the lanyard installed. Switch should be closed with the lanyard pulled.
      what are the wire colors?
        there should be only two wires on the switch so it should be easy to tell the colors when you get to the switch.
        My guess would be the back one is ground
        Have not played with a 60 4 sk but other might be white
          Thanks, i took off the tiller bottom cover and took out the switch. It tested OK. ya Black and white.
          I am a little curous about the battery. It does not sound right when it cranks. I am going to have it checked out before I go any furthere.
