UPDATE-S130TXRU
I purchased a 1998 cobia at auction this year. My first boat. I rebuilt the carbs and got the motor running. It was still bogging down in the water and on my first real day out the motor died on me twice. I took it to our local mechanic. Piston rod broke at crank. 3 grand to do a full rebuild. uGh! So I figure I’ll do it myself. I currently have it broke down. Tomorrow I start into the power unit. I have to determine if the crankshaft or internals have any damage. I have a couple questions. One is does this motor have sleeves? I cannot find a part for the sleeves. If it does not have sleeves and I have to get the cylinders bored then do I bore all cylinders or just the damaged cylinder? Also the prop shaft is bent. I’ll be replacing that. What tools do I need to pull the shaft? Also is there a walk thru or step by step for pulling this shaft from this motor? Thanks everyone!
