carburator f 100 yamaha 2003
  • carburator f 100 yamaha 2003
    hello I am looking for the o-ring diameters if possible in mm located on the carburetor 2003 F 100 engine thank you
    buy one and then measure it
      Hello thank you for the answer in order to order the joints I would have to have their dimensions greetings
        have you tried to look up the Yamaha part number?
        I have no idea what O ring you are looking for, but is it in this parts break down?
        https://www.boats.net/catalog/yamaha...100txrb/intake
          I have a fuel leak at the 3 screws that support the auto enrichener
            Look at the top picture, their 3 different part #'s (and likely sizes):
            https://www.boats.net/catalog/yamaha...b/carburetor-1
              Hello after control of my thermo starter they are to be changed in view of the price would you have alternative models like motorcycle or other greetings
                There's thousands of different sized 0-rings out there.
                You can copy the part # and do a search for it..
                If you can't find another exact o-ring(s), I'd bite the bullet and put in the correct parts.
                A potential fuel leak / fire, IMO, is not worth saving a couple of $'s..
                Good luck
