With the flywheel off for some unrelated work on my 1998 Yamaha 25 hp two stroke motor I noticed damage to the lighting coil. The wrap around coil wire was crushed and I can't imagine it works in this condition. The engine ran fine with no problems, The battery charged and everything worked electrically. This is an electric start - manual tilt motor. So my question is, what is the function of the lighting coil and will the motor run without it? It's possible I damaged it removing the flywheel but I don't think so. Any input will be appreciated.
lighting coil
