I have recently purchased a used 2001 225 hp motor. Everything was going well as expected until I started connecting the battery cables. I have the ground connected to the starter, but for the life of me I can't find where the positive cable goes. None of the studs match up (smaller) to the larger size hole on the positive lead. I attached the positive lead to the starter relay opposite to the cable going to the started. It blew the 30 amp fuse. Does the positive lead go to the relay just aft of the starter relay?
I have one rubber hose on the forward section of the motor forward of the injectors that I can't find where it attaches to. Any ideas?
