I just replaced new impellor kit and its still not peeing any thoughts . 2001 yamaha 3.1l vmax. Thx
Impeller problems?
Not peeing?
No, its not clogged, i even flushed it thru the hose adapter on the side of motor and it flowed fine. When i winterized it last winter i made sure all water was out of the system and carefully wrapped motor up . Spring came and just wasnt peeing.
A bad thermostat would keep it from working. You can take the thermostat out and put it in a pan of hot water to see if it opens or not.
I am not sure if your water pump fits on a spline with teeth, like a gear, or does it have a key way between the water pump and spline? Is the water pump actually turning? Good Luck!
Originally posted by okeechobee View PostA bad thermostat would keep it from working. You can take the thermostat out and put it in a pan of hot water to see if it opens or not.
Even in a Mercury a bad thermostat would not necessarily prevent the motor from peeing. Assuming that the badness was the thermostat being stuck in the open position.
Does not take much to plug off the small passages( a little sand or shell, or even a chunk of stuff flaking of the internal passage )and if the regulator does not get cooling flow then you can let the magic smoke out of it.
Might try blowing some air up the tell tail to see if that move stuff around enough to get a flow.
If it was working fine before you changed the water pump then I would be looking at what you did to it
If PRV is stuck open it could be dumping too much water at idle to fill the blockLast edited by 99yam40; 03-28-2015, 03:38 PM.
