one thing about assume.
break it down to 3 words and you have an assumption.
its also why I posted a quick easy test for mechanical binding once warm.
most likely its not but sometimes a warm engine requires more current than a cold one. however we have to define warm and cold.
cold assumes an industry standard of 68*F.
warm assumes the engine is at or near its normal operating temperature.
the mechanical force nessasary to turn the engine under the above parameters should be almost equal.
see how easy this is ?
a single strand of battery cable with no load will show battery voltage.
it would most likely burn in two if you tried to actually engage the starter.
remember voltage is simply a measure of electrical pressure, nothing more nothing less.
current is simply a measure of electron flow past a given point and measured in AMPs.
decrease the pressure and electron flow is reduced.
increase the pressure and electron flow increases.
now how can I increase or decrease this pressure to regulate flow??
I can add a resistor/resistance.
this resistance is going to show up as a voltage drop across the resistance.
wrap your brain around this concept: in a perfect world you could place one voltmeter lead at the + terminal and the other at the starter motor terminal and engage the starter and the reading would be 0V.
however the world isn't perfect and lugs,cables,solinoids all are going to have a resistance.
this will show up as a .5-.7V reading on the meter.
anything more would indicate excessive resistance and an associated LOSS of electron flow meaning the device wont work as designed.
same applies with the negative cable.
any unwanted resistance impedes electron flow,creates heat and drops a voltage across that spot.
like I say, see how easy this actually is???
