title is self-explanatory. Accidentally got water in the portable tank that stalled the motor. How do I drain water out of the carb? There is no easily accessible drain bolt on the carb, and the carb is mounted in a difficult to access location on the front of the motor. Could I pull the plugs and just pump clean fuel through to the cylinders with the fuel bulb?
Suggestions? I prefer not to remove the carb since this is a near new engine.
