Hello all, I have a 07/2006 F150TXR that is hard to start sometimes. It seems to be after it has been run. I took it for an 1.5 hour trip and then it sat for a couple of hours. It was turning over but not running or immediately shutting off. Had to rev up the motor in neutral for a few second and then it stayed running. It did it before a couple of weeks ago when I got home from the boat ramp and flushed the engine, about 20 minutes after I pulled it out of the water. I have had the oil and plugs changed, and the injectors were cleaned with new screens. Other than this the engine runs perfect.
Thanks Rob
Thanks Rob
