Wiring on 55 hk yamaha 1984
  • Wiring on 55 hk yamaha 1984
    Hello!
    Kan anyone tell me the color-codes for the wires on my yahamha 55hk 1984? I know that the red is continiosly power(+)d I think the blue is electrical choke... but what wire does kill the engine and etc?
    Torzt
    If you are talking about the wiring at the main engine harness
    Red 12 volts positive
    Black 12 volts negitive
    White ignition stop wire
    Dark Blue choke
    Brown starter relay
    Yellow 12 volts with key on
    Dark Green tach signal
    Light Blue trim up
    Light Green trim down
      Thanx mate! Thats what i needed.
      Do you know if the white stop cabel is going to be grounded(-) or positive(+) to stop?
