Lower Unit Issue - 2 Stroke 115HP
Originally posted by panasonic View PostMotor of that age ran in salt water, it isn't coming out even with the proper spanner.Jason
Originally posted by Jason2tpa View Post
That's the equalizer here ^^^ .... on whether its worth my labor or paying for labor to get the carrier out. I have no doubt its original and likely to have never been pulled. 22 year motor ran in saltwater.....I don't have much faith here.
Originally posted by Jason2tpa View PostGot it....
The only real investment at this point is some of your time.Scott
The outer prop seal looked very worn. Considering the motor age and saltwater exposure throughout its life, and my guess that the carrier has never been pulled, my plan is to replace both prop seals, shifter and drive shaft seals, then pressure test. If pressure holds, great....I’ll get more use out of the LU. If pressure doesn’t hold, then will likely replace LU. Cause if it’s gotta be pulled, might as well replace parts. And the cost of replacement parts and labor is nearly the cost of replacing the entire LU.Jason
To add to 99's post, it doesn't shift right now.
Before installing/investing in new seals, might try putting in some say 30 wt oil, sloch it about and see if the insides loosen up(shifts).
This would also allow you to flush out any broken off rust, left over water, etc... If it still doesn't shift, re-sealing is a waste of time and money..
.Scott
To add to Scott's post. The Gland Nut, which is the big outside threaded ring that has square notches in it all round, in your picture, has to come out to remove the prop shaft seal/bearing carrier.
So if you have that removed, you get to have a look inside somewhat and maybe see what is "making metal" in there.
I'm certain I've read on this forum countless times that one should not move into/out of gear if the driveshaft is not spinning. I'm not crazy here, right?!
If I'm not crazy, why does the service manual not indicate the need to turn the driveshaft when checking gear complation?Jason
