I have a 2012 Yamaha 25 LEHB and would like to install a spin on fuel filter. Before doing so I wanted to ask forum users if the fuel pump can handle the additional flow restriction that might be created by adding a screw on filter. Your thoughts would be appreciated.
Adding a spin on fuel filter
Originally posted by 63ihscouter View PostI have a 2012 Yamaha 25 LEHB and would like to install a spin on fuel filter. Before doing so I wanted to ask forum users if the fuel pump can handle the additional flow restriction that might be created by adding a screw on filter. Your thoughts would be appreciated.
Originally posted by robert graham View PostFor a 25HP motor the Walmart/Attwood fuel/water separater for $28 will do the job just fine....no worry about fuel pump/fuel flow. I unscrew mine and dump it maybe once a year, replace the filter cartridge about every 3rd year. Each time I've replaced the cartridge I've hack sawed it to inspect the paper element....every time it looks pretty much like new....these filters a like **** for the preventive maintenance of your fuel induction system...
+1 on getting about 3 years out of the filter..Scott
Originally posted by robert graham View PostDid I recall from previous posts regarding coast guard regulations regarding those clear plastic bowls?....maybe it was about inboard applications?....just trying to recall....
Fuel line is kinda the same - one type (typically grey - B1) is required for OB's, whereas inboards can use A1 (black). Same construction, with the only difference being the outer covering. The OB hose has a UV-rated covering. Inboards could actually use either.Last edited by DennisG01; 03-09-2015, 09:05 PM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
