My rectifier was replaced last year and now I'm having charging issues again. I was about to bolt on a new rectifier but I decided to investigate further. The engine has always cranked slowly so I decided to use a battery tester that draws 100 amps. Battery's are good and fully charged from the on board trickle charger. I hooked it up the the power posts under the floor where the battery cables meet the cables leading to the engine and checked out "good." I then hooked it up to the starter post and ground on the engine and it reads not "weak," but "bad."
So I am guessing bad cables to the motor. I cleaned all posts and contacts last year with no difference. Like I said, she always cranks slow like a weak starter or battery. I am assuming this is why I am having issues with the rectifier/regulator. With a multimeter the voltage drops to 9 volts while cranking.
Do I have to purchase Yamaha cables or can I use automotive? I would seal them up on the ends.
