Hi All!
After a great day out with the motor, I pulled in as usual to dock @ idle in forward; shifted to neutral - then tried to shift into reverse to stop the boat to park it. For the first time, I experienced tremendous resistance with my 703 Remote control box. I suspected the cable clips popped on the motor end, but was wrong - they were secure. I suspected it was time to change out the remote cables (I'm using the cables I purchased the boat with in 2014) but after removing the control shift cable end from the motor, my 703 worked smooth (no binding or evidence of cable wear) I was able to manually shift the motor quite easily to forward and neutral at the motor linkage; but reverse was so difficult to shift to that I thought forcing it was a bad idea.
At this point, I realize I need to pull the lower unit and inspect the shift rod to see if that seems as stiff as the motor linkage to slowly work my way down to the shift cam and / or dog clutch that after years of use could be warn and of need of replacement. Does anybody have any suggestions on how to pinpoint what the potential problem could be short of removal and visual inspection of the gear case ? It just happened today on a fishing trip, and first thought to post on the forum first. I'm hoping to fix the job this weekend. I do have a service manual, Clymer and Seloc books to scour for troubleshooting next. This forum is usually my first choice because there's nothing that comes close to the value of an experienced marine mechanic who sees issues like these regularly and may be able to offer a valuable approach to troubleshooting and fixing it.
Thanks!
Thanks!
