I have a 2000 40TLRY that runs grate except max.rmp. It will run at max rpm for about 30 sec. and then cutout but keep runing. If I slow down untill it settles down it will run at max rpm for 30 sec. again.
Most probably a restriction in fuel flow/fuel pump/fuel system venting issue...it just can't get enough fuel flowing to maintain wide open throttle....
