I was wondering how to check the ignition timing on a 2011 2stroke 9.9 hp outboard yamaha , and what are the specs ,rpm , I can see a mark on the flywheel and indicator on the case , also is cylinder number one used and is number one cylinder the top one? To adjust is it done but turning the adjustment rod advance lever?
Don
Don
