I have a 2006 90tlr on a pontoon that is not charging.
I checked ac voltage on the 2 leads out of the charging coil and I get around 20v idle up to 130ish volts near full throttle. Nice smooth voltage increase throughout rpms. I assumed this was good but could not find specs.
I left everything hooked up and disconnected the red lead on the regulator/rectifier to check voltage. It shows no voltage. I purchased a used guaranteed replacement and it gives the same readings?
Anything else that could cause this?
