Have lower unit off...I did it by pulling the rod up while rebuilding water pump & can't get it to go down. HELP
93 25hp 2 stroke C25MSHR stuck in forward
PROBLEM SOLVED.....Drain oil from gearbox so as there is no resistance. Mount the lower unit safely with prop shaft pointing downward (toward earth), using rubber hammer, tap near propeller until you it click, shift rod into reverse. This allows the slide shaft to go towards the propeller allowing the shift control to fall back to the end of the slide shaft.
Reference to the spring tension, by removing the hypoid grease and keeping it in a warm location you can get the shaft to drop down just enough to allow the odd shaped end on the shift rod to drop in behind the shaft. Everything is working just fine now. The worst part is that I knew enough not to pull the rob up in the first place, and wasn't even drinking yet. Thanks to all, Basil
ÂÂÂÂÂ
