Hey all, This is whats been going on with my boat.
A few months ago we started having an intermitant trim issue where the switch on the throttle and on the motor would have no effect besides a clicking sound in the relay. Then the trim stopped working all together but the clicking sound persited when either of the switches were pressed. Last week we were out and the boat kept wanting to die I managed to get it in but had to restart the motor several times. I replaced the fuel filter and all seemed fine but then after a few hours of running it wanted to die again. So we pulled the boat out of the water and let a mechanic take a look at it. He got the trim working again for a little bit (not sure how) but then he said it stopped working all of a sudden(relay died I guess) We where going to use the boat this week as we have company comming down so we went to start the boat and nothing no click just silence. I went and bought the $160 plug and play switch from a dealer and still nothing. The battery is charged. I'm getting voltage at the starter selinod by putting the volt tester to hot lead grounded on block. Havent tried to jump the starter with battery yet.
My main question is if the mechanic burnt up the trim relay could he have burnt up the starter relay at the same time since they are all in that one unit at the front of the motor... Also I put a volt tester on the main plug for the ignition switch and none of the contacts had voltage and when I hit the starter none of the gauges move but I still have power for the radio and lights when I turn on the master power switch.
Thanks David
Thanks David
