OOPS,, Merc TSB stated in 15 days is possible. YIKES !!
Yamaha F150 mystery substance in VST tank
Originally posted by Keithbaja View Post. on another note: I don't sea anyone hear ever talk about "Salt Away". Great snake oil. But don't rinse it out. First (with muff's) leave on fresh water. Then introduce the S/Away. And turn motor off. Leaving the damn stuff where it should be.. in da motor
I use Salt Away and can say W/O doubt, rinsing (no scrubbing) the engine with water alone OR with SA (mixed with water of course), there is a definite difference. You see and FEEL the difference on the surface...
This is with considerable salt build build up on a (before going out) SUPER CLEAN cowl and rest of the engine...I'd say probably 90% of the salt is gone.
I know SA does NOT claim to remove salt built up from inside the engine.
Not related, but once I pull up on the boat lift (engine still running), I hook up the fresh water hose to the Yamaha "power head hose flusher" and flush (while the t-stat is still open,).
I do run the engine on muffs with SA also.
.Scott
ÂÂÂÂÂÂÂÂ
