My alarm went off for low oil on engine tank, tank oil pump did not fill and the emergency switch would not fill engine tank. Any suggestions for diagnosis of pump failure or wiring sensors? I was able to add oil to engine tank and engine runs without alarm, but nothing working on oil tank pump.
S175TXRW. Oil transfer pump stopped working
If the toggle switch does not turn on the remote tank pump it is not a sensor.
It could be the pump, it could be power supply to the pump, ground wiring from the pump. If the pump runs but no oil is flowing it could be a clogged strainer or a kinked oil hose.
Originally posted by Luckydog210 View PostWhat is the wiring to check the pump with directly connecting to the battery ? Black negative ground? Does the tank have a strainer ?
Originally posted by boscoe99 View PostIf the toggle switch does not turn on the remote tank pump it is not a sensor.
Usually the problem with a known good pump not running with the toggle switch pressed is the harness from the motor to the pump. Specifically the brown wire (battery voltage) and/or the blue wire (ground from the toggle switch).
Originally posted by boscoe99 View PostUsually the problem with a known good pump not running with the toggle switch pressed is the harness from the motor to the pump. Specifically the brown wire (battery voltage) and/or the blue wire (ground from the toggle switch).
zpbshar.jpgJason
Â
