250HP OX66 Overheating at Idle
  • 250HP OX66 Overheating at Idle
    Good evening everybody,
    Have had an overheating at low idle issue with my 2000 250HP OX66 since last season. Have done a ton of research and still can’t resolve it. Above 1,100RPM it doesn’t overheat (In water, not earmuffs).
    First thing I did was replaced both thermostats and the poppet valve system. Replaced water pump and housing (twice). Still doing it. So I opened the heads and started cleaning all the water jackets/passages (on both sides). Even tried flushing with light acid mix. Hasn’t fixed it. I couldn’t find a diagram of how the water travels through the block. Maybe something is still plugged?
    Last week I went out and noticed a lot of water coming out of the exhaust. I know water exiting through there is normal, but how much? I never opened the middle/exhaust part of block. Any suggestions will be appreciated. Thanks.
    maybe it is time to board scope the exhaust
      Board scope?
        Pretty sure it was typo and he meant borescope. I actually have one but will see if I can open middle exhaust portion on block. Was afraid of breaking a bolt but will hope for the best. Any other suggestions? Thanks.
          Board scope?
          yep you and the correction system got me I think
          op drop lower unit and shove it up there to look
            Might try removing and taking a look at the temp sensor. Could be something in that cavity that's causing a disruption of waterflow around the sensor at lower flow rates. Especially if the overheat alarm goes away quickly upon increasing the RPM.
