5/16" Barb (8mm) MALE Fuel Line Connector?
  • 5/16" Barb (8mm) MALE Fuel Line Connector?
    1.) I'm trying to find a Yamaha Fuel Line connector, to support 5/16" (8mm I assume) fuel line barb, in the MALE format. I can find 6mm barb and I can find with a metal NPT type connection.
    2.) Is my boat just rigged strangely? It has a 5/16" line running from separator at back of motor that runs to inside of boat. It has a male connector on end (that I'm trying to replace in #1 above).
    3.) From Tank back to the connection point, there is a standard 5/16" Yamaha pre-fab line with a FEMALE on both ends, with a primer bulb built in. The Female of the pre-fab line has to fit to a Male. (There is male coming off the tank, but I can't find a male with 5/16" line connection for the engine side of the line.)
    4.) I do not have a separator in the boat, just the small one on back of motor.
    It is 15 years old and I am replacing from tank to separator tank, but the one piece I'm missing is a Male Connector to put on the end of the hose coming from engine.
    Any suggestions? (I've searched on and off for days online. I don't want the 'tank' fitting. I need one I can barb into a line.)
    2005 F115 TLR
    Or should I just run hose straight from the primer bulb to the separator on engine, with NO connection fittings between the bulb and the separator?
      what is wrong with the one on there?
      a pic of what you are looking for may help
        If do-able W/O much issue and done correctly, they'd be one less joint for potential failure / leak.
          why doing: existing line was 15 years old, making sure I have good line from tank to engine
            as I said, why replace the fitting that is there, was not talking about the hose
