Originally posted by briankruz
View Post
2004 F115 Temperature Gauge Flash at High RPM (no buzzer, no engine reduction)
I replaced the shift position switch which cleared the irregular signal from the YDS. Took the boat for another spin. Real overheat: Blinking light, rpm reduction, & even some white smoke/steam. Shut it down as soon as it was safe to do so. Now when I start it it does not piss. When I hookup the hose to the flush port it does piss.. Plan to pull it out, drop & inspect the water pump/impeller which I assume is cooked. Nearing the end of my rope. Likely heading in for service depending on what I find.
Originally posted by TownsendsFJR1300 View PostPer your first post, was the WP replaced BEFORE the issue started?
Or did the issue arise AFTER the install... Kinda sounding now like the install may be the issue...
Originally posted by TownsendsFJR1300 View PostSalt Away won't damage the WP, not enough water (leaky muffs), of course will..
Good luck on the sea trial..
Originally posted by briankruz View PostSeatrial was successful in a way. No real overheat, but the temp light remains blinking. I verified the thermostat was open when I returned to the dock. It also closed fully.2011 F50TLR, 2010 G3 V167C
Boat is still there (island time).. Hopefully will have it Monday-Tuesday. Problem ended up being the oil pump. They had to pull the powerhead to replace it. They say the team was going off at high RPMs because the oil wasn't reaching the top of the motor effectively. That would explain the oil light alarm at startup.
