F100 flywheel removal
  • #31
    Originally posted by almetelo View Post
    Timing belt got some WD-40 oil type (not much) from when I soaped the flywheel/crankshaft to release the flywheel, that may be a problem?
    Rod, If I'm not wrong guess I've read on a previous post you prefer a analog/needle DVA, any diference from a digital?
    Any thoughts?
    • #32
      Doubtful. Wipe it off and it should dissipate - remember, WD40 isn't really all that good at "sticking around", anyways. You could spray a little Brakleen to clean it up. Use the non-chlorinated stuff (green can) just to be safe.
      • #33
        I use a CD-77 if hunting for intermittent issues.
        the digital buffers to slowly to catch most intermittent.
        for testing a stator lighting coil a digital will work just fine.
        • #34
          Right, know what you mean...
          I have a CDI 511-9773 and Blue Point MT586B10 even so one more than I need as I'm not in the business.
          So one of the above will be just fine.
          Thanks!
          • #35
            Hi!
            Just to keep you posted...
            Unfortunately just now I had time to have my KL16 out of my basement/garage (much later than last years/desired)
            After clean the stator (something that had to be done) the problem of slow battery charging persisted so I didnīt even test the R/R and swapped by a spair I had in case of failure (being this a common fault on this model)
            Guess what!?
            Problem solved!
            Thanks guys
