2005 F225 TURDS....
Twice in the last ten hours of operation, I've had to pull the VST and clean the High-Pressure Pump's intake screen. Twice in ten hours. Good thing I don't pay a local mech to do my wrenching. The screen gets clogged with tiny black particles of crud and they mechanically block the flow of fuel into the pump. The first stage filter on the front of the engine is spotless.
Therefore, that crap is only coming from the degradation of the inside of fuel lines downstream from the VST. That gets sloughed off and is then returned to the VST by the injection manifold and associated hosing. Those bits small enough to get through the screen eventually clog the injectors. Been there and done that. Getting ready to do that again.
I am going to replace ALL of the fuel lines on the engines. Yamaha wants 40-50-60-70 bucks for EACH SHORT bent pieces of hose. We know that the engine is covered with them. So what, 500-600 bucks or so per engine for fuel line? Nuts.
I am going to replumb all of the long hoses with aftermarket straight hose. I am going to run a pipe cleaner through the short (50 dollar) elbows and other shaped sections. If they come out clean and show on signs of internal erosion, they're going back on unless I can make a new, straight piece work in their place.
SO....
Can anyone recommend the best source of aftermarket hose that is the proper diameter for these engines and can anyone speak to the suppleness of the hose?
It looks to be 1/4 inch, but it doesn't say so on the YAM hose.
** As an aside, buy a set of used YAM (Bosch?) injectors for your engine on eBay. You can get a rebuilt set for less than one new injector from Yamaha. I keep a spare set and when I need them, just pop them and then send the old set off to Mr Injector for cleaning.
SO....
