2006 90 hp 4 stroke power loss
  • 2006 90 hp 4 stroke power loss
    I have a 2006 Yamaha 90 hp 4 stroke motor that bogs down and loses power after a few minutes of running. Starts fine, idles and no wake speed runs fine. I’ve changed the plugs and fuel already. Looking for advice on what the problem could be
    do you have have gauges that will tell you when you have an overheat or low oil pressure?
    does you alarm system work or at least the buzzer?
      I do have the low oil and overheat lights but haven’t tried to test them, just assume that they should work.
        could be over heat.
        test the alarms/lights to see if they work
