I have a 2002 LX250 OX66 that shut down while trying to get on plane. I was able to run slowly back to the dock.
i cleaned the filter on the high pressure pump
I cleaned the screen on the pressure regulator
I cleaned the O2 sensor and replaced the gaskets
i replaced the 3 LP pumps
i replaced the fuel filter on the motor
I replaced all fuel lines and ball
i replaced the fuel water separator
I replaced the injectors
I replaced the spark plugs
i calibrated the TPS
both batteries are reading 12.6 volts with or without the motor running. I always keep a tender on it to charge the batteries. Charging circuit does not work
I tried to post a video but it’s not working It says unknown error. Just like my motor.
