Could a bad fuel pump cause hard starting and dying at low idle as in idling towards the dock. other than that motor runs perfectly fine. thanks for your input
25 hp 2 stroke hard start
most shops do not rebuild them because their labor charge is so high, they can just replace it cheaper.
You can take yours apart and see if you find a problem, just a few bolts to take it apart.
but my guess would be a problem inside then carbs if compression, spark ,and timing are goodLast edited by 99yam40; 02-03-2015, 08:29 PM.
ÂÂÂÂÂ
