2000 25hp 2 stroke fuel pump rebuild
  • 2000 25hp 2 stroke fuel pump rebuild
    I've never done a fuel pump rebuild and was wondering if it is very difficult? They want a lot at the dealership to do one. All info appreciated
    Absolutely not difficult!
    Donīt be "affraid", do it...
      The entire new pump is about $55 so why screw with a rebuild?....I put a new pump on my C90 ever 5 years or so and keep the old/operating one for a spare....
        Thanks. Thats probably what Ill do.
          price all the diaphrams and gaskets.
          you will find its almost 25 bucks give or take.
          a pump is about 45 dollars new.
          now I take 25 dollars worth of parts,head over to the work bench.
          spend 15 min disassembling cleaning and reassembling your pump at 80 bucks an hour.
          you now have a brand new rebuilt pump.
          its why I don't rebuild them.
            Isn't that pump part of the carb bowl? What is the part number for complete pump if anyone knows? That design isn't hard to service, other than removal of that carb may be needed. What is your engine model number?
              Seems that is correct
              that motor has the pump built into the lower carb.
              So best to buy the parts needed to rebuild
              Did not see anything about a whole pump
              There is a kit
              http://www.boats.net/parts/detail/ya...093-00-00.html
                Yep, kind of tough to buy a complete pump when one is not available. Just cause one Yam model has a standalone fuel pump available (or two) won't mean that another Yam model has a standalone fuel pump.
                A Yam is not a Yam is not a Yam.
                I don't believe that the carburetor repair kit has the piece parts needed to rebuild the fuel pump.
                Would be nice to know if this is a two cylinder or three cylinder 25 HP model.
                Why is it so hard to post the complete model identity?
                  if its the two carb two cyl the pump is part of the lower carb.
                  the 2 cyl single carb and the 3 cyl 25 uses a separate pump.
                  so far we have 3 25 hp yamahas that pretty much only share that they were made in japan.
                  I still need an alternator for a ford truck
                    I thought the 2000 3 Cylinder pump was on one of the carbs also
                    This is very true.
                    Model # would tell for sure how it is built and if it truly is a 2000
                    You would think people could post the complete model # very easily when ever they ask about a motor
                      Dammit! What colour alternator?
                      Where in Japan is an F6 made?
                        Rodbolt, post #9 , no we don't. Original post #1 says 2000, 25hp, 2 stroke.
                          Looks like for the 2000 model year there are only two choices. Both seem to have somewhat integral fuel pumps.
                            now the question is
                            Is this really a 2000 or just manufactured in 2000.
                            Model # will tell
                              I see where you're going 98yam39, I think its a 2006 135hp Evinrude ETECH.No pumps at all on those carbs, in fact, no carbs at all. But there must be a rebuild kit for a 1997 Honda 90hp, maybe not though. I'll check with Hupmobile. There are but they are backordered until 2022.Guess he has to buy a new motor. Maybe a Seagull Forty Plus.
