Hi,
I just bought a Yamaha 4 hp 2 stroke longshaft from 1994. It starts right away, but when i accelerate the engine just dies until I put it in idle.
When I put in in gear, the same thing happens. If i play a little bit with the choke (opening and closing quite fast), the engine appears to work just fine when throttling.
This model only has a built in tank, with a fuel tap next to the killswitch. I already noticed that some fuel leaks from the bottom of the fuel tank, where the tap opens and closes the access to the tank, but i think something else causes this problem.
Any thoughts on this?
Thanks in advance!
Thanks in advance!
