2006 yahmaha four stroke
  • 2006 yahmaha four stroke
    I have a 2006 115 Yamaha four stroke that I took out on Saturday and it ran fine ,parked it overnight and at the boat ramp the next morning I had no power to the engine or tilt controls .I have checked batt voltage and fuses and all seem to be fine . Any ideas on what the problem might be ? Thanks
    Remove, inspect, clean and grease battery and ground connections....often corrosion will form at these connections....
      Just to add to Roberts post, if you have a battery switch, check voltage before and after that as well.
      If you can't find anythng amiss, start at the battery for voltage (12.8 or so) and follow until you find where voltage drops off..
      Last edited by TownsendsFJR1300; 01-21-2015, 08:40 AM. Reason: Highlighting troble shooting procedure
        have checked battery for voltage and have checked batt connections both are new batteries ,I do have a batt switch and have power to all accessories horn bilge radio etc ..thanks
          Check for power at the engine??
