I have a 1999 250 ox66, Ijust put the boat in the water and noticed a sheen on the surface of the water, which I traced to a leak from the single pistion for the tilt. It looks like a pin wrench would get the nut off. Can I do this with the boat in the water? I recently replaced leaking nut seal on the hydralic steering shaft. It seems like a similar repair. Also where is the fill port located and what kind of oil do I use?
Thank You GUY B.
Thank You GUY B.
