What is best method to release tension. Using the manual it says to turn hex clockwise. No movement?? Seems odd.
2004 Yamaha F150 Tensioner
According to what I recently read here, there is no special training required to release the belt tensioning device on an F150. Just keep turning it. Use a breaker bar if needed. Then when it breaks buy a new one at $340 a pop. It will then be really easy to install.
Just being facetious of course. That sumbitch will break on you in a nanosecond if the proper procedure is not used.
You will want to use a torque wrench to turn the hex fitting. Beam type works best. Apply a very, very light load to the torque wrench very, very slowly. No more than 100 lb-in of torque. Did I mention to apply the load very, very slowly and very, very lightly? 100 lb-in almost feels like nothing. Best to use a torque wrench that has a very low scale and with more than likely a 1/4 drive.
Oh, and go slowly. Send me your email address via PM and I will send you some data that addresses the appropriate release procedure.
Originally posted by boscoe99 View PostAccording to what I recently read here, there is no special training required to release the belt tensioning device on an F150. Just keep turning it. Use a breaker bar if needed. Then when it breaks buy a new one at $340 a pop. It will then be really easy to install.
The Yamaha Service manual does not give you the straight skinny on removal.. Just says insert hex wrench turn clockwise and insert pin. This is a recipe for disaster. You follow the service manual(at least the one I have from Yamaha) and you cant help but bust it..No wonder so many techs break these damn things..
Originally posted by Nautical View PostThe Yamaha Service manual does not give you the straight skinny on removal.. Just says insert hex wrench turn clockwise and insert pin. This is a recipe for disaster. You follow the service manual(at least the one I have from Yamaha) and you cant help but bust it..No wonder so many techs break these damn things..
You are not the first to have broken the tensioner and I daresay you won't be the last.
Does the term "pot metal" come to mind?
ÂÂÂÂ
