1997 C25 Ignition Question
  • 1997 C25 Ignition Question
    I have a 1997 C25 MLH. I have the factory service manual. I have cleaned and rebuilt the carb. New plugs. Been decarbonized. Clean fuel at proper mix.
    I have a miss from low idle (1100 per manual) through roughly 2500, then it smoothes out through WOT
    I cannot get the timing in specification using a timing light. Full retarded timing is 6 ATDC +-2. If I have the bracket adjusted all the way to retard, it won't go below 4. I know that is within the lowest spec tolerance, but then I cannot get 22BTDC WOT spec.
    I have tested the pulser coil, charge coil, and primary and secondary coil resistance. All are outside of what the factory manual specifies. I verified the resistance readings with two different DMM's
    I find it hard to believe that every part of my ignition system is bad. I have not tested the CDI box yet.
    Also, the manual shows two pulsers and two ignition coils, I only have one of each, so is there a possibility the factory manual is wrong? Did they change something mid year?
    ​​​​​​​Thanks for your help!
    Not unusual for a Yamaha SM to have errors.
    What are the values that you recorded for the ignition system components? Resistance and voltage please.
      Coil primary resistance is .3 ohms. Manual specs .18 - .24 Secondary side of coil- It starts reading and then climbs beyond the scale.
      Pulser coil is 106.6 ohms. Manual specs 311 - 381
      Charge coil is 240 ohms. Manual specs 342-418
      My manual does not have voltage specs, and I do not have a DVA.
      Edited to show manual specs.
        I have tested spark gap and it is hot blue at a 10mm gap
          I have a feeling you do not have a Yamaha service manual, maybe an after market one, but I could be wrong.
          peak voltage is the best way to test, but since you show good spark, what are you concerned about?
          I have no idea what manual would call for 1100 at low idle
          did you verify the timing mark at TDC for #1 cylinder?
            I built a DVA. These are my voltage readings at idle
            Charge coil 248 vdc
            pulser coil 25 vdc
            When I get this corrected, I will post the solution, so that maybe it will help someone else searching this problem.
              Go to http://www.cdielectronics.com/ and look up your engine...it should have the peak voltages you are looking for.
